Need Help!
Old Mar 2, 2009 | 03:22 PM
Mediaz's Avatar
Default Need Help!
I'm putting together a honda civic Hatchback 98 which has a D15B2 block and a D16Y8 Vtec head, which is the best and easiest ECU to hook up? I already have a P28 and the jumper harness, I also passed the vtec solenoid cable thru the fire wall and connected to A4 pinout, what else I have to look up to? Car Idle perfect but if I a give it gas it dies, took spark plugs out and they look like if the car is running rich, also I cleaned the IAC, but not improve at all, thanks for your help.
Moe
Old Mar 2, 2009 | 04:52 PM
Jump the service connector and then check the ignition timing with a timing gun. Is the CEL ON?
Old Mar 2, 2009 | 05:05 PM
Mediaz's Avatar
Yes the CEL light is on, I'll try to find the service connector, really the harness is a mess, there is a lot of connectors without a partner to go to, so If I can make it run, first thing I'll do is organize the wiring harness, it does not look good at all.
Thanks for your help
Old Mar 2, 2009 | 05:09 PM
The service connector is generally located just above the ECU (see CEL link in my signature). This connector is used both to pull CEL codes and to set/check the ignition timing. Good luck with fixing the wiring mess.
Old Mar 3, 2009 | 03:19 AM
Mediaz's Avatar
Thanks RonJ, your info. is very helpful, I'll let you know how it goes.
Thanks again
Moe
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
Jas10hon
Jul 4, 2005 10:35 PM
CivicCrazy
Nov 29, 2004 11:50 AM
