need help 98 civic not starting
Old Mar 24, 2009 | 12:25 PM
Was the no-start fix to replace the main relay?
Is the CEL ON? If not, the ECU probably needs a little time to relearn the idle. Remove the under-hood 7.5A BACKUP fuse for 1 minute (clears ECU) and then reinsert. Drive the car for 30-minutes. The idle may settle down after this time.
Old Mar 24, 2009 | 01:04 PM
Ron has an excellent point. First the CEL has to stay off, if not you need to fix that first before expecting it to run properly. Then you need to drive some to recalibrate it.
Make sure that the back up fuse is not blown. If the fuse is blown the ECU will never stay in calibration, and it will idle poorly every time you start it.
extreme
21
Jun 3, 2008 06:54 PM
bruiser_696
Jan 3, 2008 04:06 PM
redmachine07
Aug 19, 2007 11:51 AM
totenkopf
May 31, 2007 03:36 PM
dgaf3888
Dec 27, 2006 06:43 AM
