Need help with my a/c
Hello,
I have a 2000 honda civic cx hatch, my a/c had a hole in one of the pipes. The pipe was replaced and new r-134 was pumped in but in a month or two the a/c just lost its cold air. Can anyone help me with this problem?
Maybe there is another leak? You can check for leaks by hooking up a vacuum pump to the A/C and putting the A/C system under vacuum. Take the vacuum pump off and leave the gauges on. If the A/C holds vacuum then there is not leak. Since you had a prior leak that is what i would look at first.
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
CivicCrazy
Nov 29, 2004 11:50 AM
