need help now, proportional valve
i think i have a civic si proportional valve and it looks really differ than the open one on my civic cx ek hatch back and im doing a swap .. im all set but i just need to know how to proportional valve goes like .. i have one thats 2 on one end and on the opposite its like a square .. im thinking that the square would go just like the car would u know one end would be for one end im but im not sure though.. i need help
http://i18.ebayimg.com/03/i/07/47/29/b2_1.JPG
this should be an example .. integra brake proportional valve .. i also remmeber that doing a disk brake conversion im not suppose to use a integra brake proportional valve? ? im done with the disk brake and everything but brake pedal kinda loose ... gotta rebleed the system and i donkt now if i wired everything to the proportional valve correctly .. but when i press brake it seems fine ..
yeah ive changed the mc and brake booster but the proportional **** was a bitch .. i assumed as that the set up is like the front ones are front left and right rear are rear left and right depending on how u bolt it on .. and when i was done it was cool
brake pedal feels sorta loose till and gets stiffer as i press it in more .. like in the middle
i think i probably gotta bleed the brakes better
but i do have an issue with the ebrake .. it is hecka stuff . maybe i have to .. adjust it ?
Aaron A Archer
Nov 29, 2011 08:37 PM
Slammed98silvercoupe
Oct 29, 2010 04:20 PM
bigmreds64
34
Dec 21, 2007 07:09 PM
mill$civic
Oct 31, 2005 06:25 PM
jlh911
Jun 30, 2005 09:52 PM
93, civic, honda, integra, prop, proportion, proportional, proportioning, si, stamp, stamping, swap, valve
