Need some Wiring help.
Old Aug 6, 2010 | 06:51 AM
DaOne's Avatar
Default Need some Wiring help.
I just got a del sol the other day, and i got a few questions...
1) the first thing i noticed was that the Radiator fan was always running, even when the car is cold.
i then looked under the hood and found out that the cables running from the fan where cut and extended... one goes from the fan to ground, and the other one goes here...
2) The del sol came with a d16z6 swap, but did not come with the new ECU. it came with the stock P06. Will i be able to pass emissions even tho its not the right ecu? or do i need the p28 ecu to be able to pass smog?
3) does anybody know what this is?
Size:  123.1 KB the car supposubly has an alarm... it has a remote and it beeps and a blue light flashes and all that. but That thing stuck on the windshield has a light that never flashes or anything. so maybe its something else?
Thanks a lot!!!
Old Aug 6, 2010 | 02:56 PM
SilverSedan's Avatar
Rad Fan: I'm guessing that there is a problem with the rad fan not coming on when it should, so the previous owner likely just wired it to come on whenever the ignition is in the "on" position. (I have done something similar for a temporary solution till I could resolve the problem). My guess is that the ETC (Engine Temp circuit) is the problem, but you'll have to do some troubleshooting to be sure.
ECU - no idea, someone else will have to help you
The thing on your windshield is likely the antenna for the alarm system.
Old Aug 6, 2010 | 03:24 PM
DaOne's Avatar
Yeah thats wat i was guessing for the radiator fan.
i just need to figure out whats wrong with that lol. will any sensor from like a 92-99 civic work for my fan? or will it need its own special one?
yeah maybe thats what the antenna is, but its just wierd because the light on it never flashes or anything. lol
btw i really wanna know if having a d15b7 ecu will make me fail smog... i dont wanna go if its gonna be a straight up FAIL. lol
Old Aug 7, 2010 | 04:25 AM
for the rad fan: first things first - make absolutely sure there is no air in the cooling system. For some reason on my car its a royal PAIN to get the air bled out properly. If there is air in the system, then the fan switch/ETC will not read properly and never turn on the rad fan. Also check the relay (swap it with one you know works). On my car (a 97, d16y7) the ETC sensor is screwed into the thermostat housing and its a 2 wire sensor. Once it reads a certain temperature it will close, and turn on the rad fan. Once you have the rad fan wired back to factory, you can unplug this sensor and put a jumper in to check the wiring and relay of the rad fan circuit.
Hope this helps
Old Aug 7, 2010 | 04:27 AM
oh yeah, and I'm guessing the sensors may be different from 92-95, and 96-99. They might be the same, they might be different. You'd have to check that out.
joelmatt89
Jan 26, 2009 06:08 PM
madjoker14
Jun 2, 2007 09:31 PM
Stumasters
Feb 12, 2007 02:34 PM
AWeb80
Mar 23, 2006 05:44 PM
93EXCivac
EG Swaps
Jan 21, 2006 04:30 AM
