New (to me) 96 Civic barely passed smog!
Old Jul 5, 2010 | 06:45 PM
Dannicus's Avatar
Default New (to me) 96 Civic barely passed smog!
Hi everyone! I'm new to the forum and new to Civics. I just picked up a '96 Coupe D16Y8.
The smog tech told me I was borderline fail on NOx. He said I'd need a new cat soon and a tune up was probably in order. What should I check/replace to get it in spec? I though it might be primarily due to a bad EGR valve but i hear this model doesn't have one.
Old Jul 5, 2010 | 07:05 PM
What were the other numbers? If HC and CO were supprisingly low, could be running lean. If all the numbers are high most likely bad cat.
Old Jul 5, 2010 | 07:38 PM
Dannicus's Avatar
______________Measured________Avg____________Max
15mph/25mph
CO2(%)_______14.5/14.5
O2(%)_________0.0/0.0
HC(PPM)________29/19__________9/7____________66/49
CO(%)________0.3/0.12_______0.02/0.03________0.57/0.55
NO(PPM)_______484/614________57/50__________487/774
Excuse me if i have little or no idea what this all means.
Old Jul 5, 2010 | 07:41 PM
Looks like the engine is running lean. Any CEL codes? If not, start by replacing the fuel filter. Also check the ignition timing.
Old Jul 5, 2010 | 08:08 PM
Dannicus's Avatar
No codes. I'll check the timing. Fuel filter's on it's way. Good idea to check fuel pressure?
Old Jul 5, 2010 | 08:10 PM
Yes
gsumano
Mar 27, 2008 09:55 AM
rukusix
Nov 18, 2006 07:33 AM
ef4life
Oct 31, 2006 09:34 AM
StifflersMom
Sep 14, 2005 04:23 PM
LEVIII
Aug 20, 2005 10:29 PM
