No spark. Need help!
Old Jun 22, 2007 | 11:27 AM
Mr Mobsta Man's Avatar
Default No spark. Need help!
Someone broke into my car and stole over $600 worth of stuff but I will make a post about that after I calm down a little bit. I'm shaking pretty bad, feel like it got punched in the stomach and have a huge headache... I can barely think strait right now.
Right now my car will not start because the rat bastards stole my spark plug wires and air intake. My mechanic cannot get it to start yet. He has replaced the wires with oem ones and says that there is no spark. He tested all the fuses under the dash and in the engine bay. The car is cranking but not starting. He replaced the distributer and it still is having the same problems. The people riped out my stereo and all the speakers. The mechanic now thinks that it might have something to do with a ground wire. Does anyone have any suggestions?
Old Jun 22, 2007 | 11:52 AM
Default RE: No spark. Need help!
Did your ECU get stolen too? You will not get sparks without an ECU.
Either that or a vital wire under the dash got broken.
Old Jun 22, 2007 | 12:35 PM
No the ecu is still there and the wires look untouched. The mechanic was looking in the dash when I was leaving for wires so it could be one of them. That is what my money is on at the moment. Also, we know there is fuel because we can smell it when we crank the car and we can hear the fuel pump click on.
Old Jun 22, 2007 | 07:10 PM
AgentofDarkness's Avatar
Disconnect the coil and check the resistance of the coil. Also, check to make sure the coil is getting power.
Old Jun 23, 2007 | 10:18 AM
Isn't the coil inside the distributer on my car? He replaced the entire thing.
Old Jun 24, 2007 | 05:23 PM
The roto said to check to see if the main relay was stolen and it is still there, car is still not starting? Any more ideas?
Cousin_Joe
Sep 17, 2008 06:44 PM
gforce79
Mar 8, 2007 07:02 PM
jmb72105
Feb 9, 2007 04:24 PM
mill$civic
Nov 18, 2005 09:52 PM
jefftheruler
Apr 20, 2005 10:18 PM
