No Spark unless letting key go
Old Jul 11, 2021 | 03:57 PM
Toxic's Avatar
Smile No Spark unless letting key go
Alright, haven't found someone with this particular specific issue, since google gives the same result no matter what
97 ex coupe with a d15b vtec swap
car shut off mid driving started twice died instantly and now does not start period
cranks and starter goes
no spark at wire/plugs (until you stop cranking you get a singular spark from test light)
everything in the dizzy works used it on another vehicle to test, all fuses/relays are good, fuel pump primes, and is receiving the fuel
the green/yellow wire from the dizzy plug (on my 97 ex) is getting no power
i believe it's the ignition wire to tell it to fire
should i try replacing the ignition switch before i tear my entire car apart to find the short or is there specific places when a pin might've slipped loose
any schematics/wire diagrams would be helpful
ConfusedGuy
Feb 7, 2020 12:33 PM
voodood7
Sep 23, 2011 07:46 PM
breakdn1994
May 7, 2008 05:53 AM
ClinDiesel
Oct 2, 2007 06:22 AM
sdimedude
22
Nov 3, 2006 07:02 PM
