Noise and vibration off gas
Old Nov 3, 2019 | 11:20 PM
jbum's Avatar
Default Noise and vibration off gas
I have a 2005 LX Sedan. I recently replaced the wheel bearing of the driver's side front wheel. When I bought the car, the front bumper and underbody panels were damaged from the previous owner having run over a tire or something. After I had the car for a year, it developed a growling noise and it turned out to be a bad bearing.
Anyway, since I've replaced it, it's been so quiet but my car has developed a new issue. Whenever I'm going in the range of 40 - 80mph and let go of the gas, I get this rhythmic noise and a bit of vibration that I can sense through the pedals.... especially the brake pedals. It has a similar tone as a tire hitting the road because it's off balance. Could an unbalanced CV axle make such a noise and vibration?
Not always but occasionally, I get a slight shimmy of the steering wheel while braking in this speed range. But it's so intermittent that I wouldn't say it's rotors warping or even out of balance wheels.
Any ideas? I tried to record the sound but it doesn't get picked up on a phone (usually only get wind noise).
Old Dec 8, 2019 | 12:10 AM
clio's Avatar
When I am driving anywhere over 40mph and I completely let off the gas pedal...I get this really loud rumbling noise and it shakes the jeep pretty good. More of a vibration shake...not like a death wobble shake. But as soon as I ever so gently touch the gas pedal...it goes away. It sounds like a wicked tire noise. I get the same noise when I come to a slow stop such as in a parking lot of something...it just sounds like 33's with bad tread coming to a stop, but I never had it happen at highway speeds before. It's just real wierd that it goes away when I'm giving it throttle.
Kodi Lucky Patcher nox
Old Dec 8, 2019 | 04:03 PM
StifflersMom's Avatar
Cat Fuсker
Move the front tires to the rear and see if the same keeps happening, but I'm willing to bet you have a tire balance/wear issue or a sticking caliper.
Old Dec 16, 2019 | 12:27 AM
jbum's Avatar
Finally got the time to examine my car again (with other issues, unrelated). Anyway, I looked at every suspension component with no luck. One thing I never tried was perform the wheel wiggle for detecting a bad wheel bearing. I just replaced it so I NEVER thought to check that.
Well, the same wheel where I replaced the bearing shakes ever so slightly and makes the small clunk/click noise when I rock it at 9-3 and 12-6 o'clock positions. WHAT?!?!?!? I just replaced them!!!
My only guess is that I may have accidentally pushed against the inner ring when I pressed in the bearing. I used one of those manual wheel bearing press kits. it was my first time using it so I wouldn't be surprised if I goofed on one of the steps. Has anyone experienced something similar?
USCGTigerFan
Jan 5, 2010 10:14 AM
runrider
Dec 20, 2009 05:30 PM
joey20046
Nov 3, 2008 09:06 AM
vital49
Aug 22, 2007 10:51 AM
johnandcookie
Nov 28, 2005 07:57 PM
