O2 sensor simulator..
Old Apr 21, 2009 | 01:11 PM
plethoric33's Avatar
Default O2 sensor simulator..
Has anyone on here actually tried these? I have a B swap and custom exhaust, and the secondary 02 was never on the car when I bought it. I added a magnaflow universal Cat Converter to the exhaust. Im wondering if i really need to get the cat drilled for a sensor, or if I can just get one of these simulators and wire it in.
Heres one of the ebay ones.
http://cgi.ebay.com/O2-OXYGEN-SENSOR...3%3A1|294%3A50
Old Apr 21, 2009 | 04:47 PM
Another question...does OBD1 require 2 o2 sensors? My car is converted to OBD1 from OBD2b with a jumper harness.
Old Apr 22, 2009 | 12:32 AM
TheJGB3's Avatar
OBDI= 1 O2 sensor
ODBII= 2 O2 sensors
Old Apr 22, 2009 | 07:02 AM
FlipHKD720's Avatar
i used that exact thing for well over a year, worked fine. If you cut all 4 wires you'll need the Heater Wire Simulator as well, but its like $10 extra bucks or something. But yes, they do work to cure the seconadry o2 sensor CEL, but in the end it's always better to just run a cat properly. Tricking the ECU is (usually) not good.
Old Apr 22, 2009 | 02:12 PM
So you still need to have 2 o2 sensors if your converted to OBD1? Its an OBD1 ecu. Just wondering, Im still using a cat, I just want to clarify that I do or dont need a secondary since im now OBD1 with an OBD1 ecu.
SkItZiAnIsT
Jul 25, 2007 03:57 PM
Remmy
Aug 25, 2006 01:38 PM
FlipHKD720
Aug 19, 2006 07:20 PM
aarona1000rr
Aug 10, 2005 11:16 AM
AOL.COM
Apr 15, 2005 06:50 PM
