o2 sensors
Old Nov 28, 2005 | 09:12 PM
tripod's Avatar
Default o2 sensors
1996 civic ex coupe 145K miles. im looking to replace my o2 sensors. honda automotiveparts.com lists two different number for the sensors. ngk's website lists the same for the upstream and downstream. any suggestions? im sure i cant send them back if theyve been installed.
Old Nov 28, 2005 | 10:25 PM
neon3kgt's Avatar
Default RE: o2 sensors
i would call the Honda dealership, and ask them if they are the same part #.
Old Nov 28, 2005 | 10:38 PM
97CivicEX's Avatar
Why do you want to replace them? The one downstream does nothing but report the health of the cat. If you have no check engine light for an inefficient cat there is no need to replace. The one upstream is the one the ECU uses to monitor your air fuel mixture and unless you are getting bad gas mileage (and have tried the usual tune-up stuff) I doubt the O2 sensor is going bad. I have a 97 and failed emissions with an aftermarket O2 sensor. I re-installed the original O2 sensor that had 160K miles on it and it passed emissions without a problem. Unless you are absolutely sure the O2 sensor(s) are bad, I wouldn't replace them with anything aftermarket.
redhonda69
Sep 4, 2005 01:58 PM
blackeyes
Mar 15, 2005 02:28 PM
hans747
14
Oct 30, 2004 10:16 AM
98brokeassvtec
Aug 23, 2004 05:31 PM
LT2004ever
Jul 25, 2004 03:50 PM
