O2 sensors on a 1999 Civic
Before you discount me why don't you read a haynes repair manual. You attitude stinks. When i give advice it is the truth. the haynes repair manual is based on the 1996 - 2000 honda civic, integra, and crv. The info i am talking about is in chapter 6, section 4. If you like i will email you the section in the book. The OBD-I codes for an o2 sensor is P1162-P1169 (48, 61, 41, 48). You probably would be better off if you hook up a scan tool to your car but if you don't have one then this is the cheaper option. If you are not comfortable doing this then you should bring you car to the dealer, he will use the OBD-II scantool and charge you.
ORIGINAL: dawnw
ORIGINAL: dawnw
ORIGINAL: dawnw
When i give advice it is the truth. The info i am talking about is in chapter 6, section 4. If you like i will email you the section in the book. The OBD-I codes for an o2 sensor is P1162-P1169 (48, 61, 41, 48). You probably would be better off if you hook up a scan tool to your car but if you don't have one then this is the cheaper option. If you are not comfortable doing this then you should bring you car to the dealer, he will use the OBD-II scantool and charge you.
88-91 obd0
92-95 obd1
96-98 = 2a
99-00 = 2b
In conclusion, don't trust all of the content in a Haynes. I've looked through many a Haynes on cars I know tons about and seen some pretty blatantly incorrect/overly generalized information.
Oh and...
ORIGINAL: dawnw
Hey Mr. knowit All
The buttton line is that newer cars use OBD-II but they also have OSB-I. You can use either or. The next time you post info, se your head! I don't care that you don't like haynes manuals because the fact of the matter is that the procedure that I posted works. OSB-I do apply here because it can be used in this application.
P.S. The next time you open your mouth do so homework first.
ORIGINAL: dawnw
Hey Mr. knowit All
Hey Mr. knowit All
You talk about "discounting" someone and all this other bullcrap nonsense, you're such a little hypocrite. Perhaps you should listen to yourself before you discount me. Perhaps you should know me first before you hop in that pot, mr kettle. You have no idea my background and you have no idea what kind of research I did. So before I get another letter like this in my email.
If you want the OBD-1 Codes for a 1999 honda civic i can email you a section of
the haynes repair manual. To discount people is ignorant. Before you discount
somebody you should check the facts for yourself. I was told that i needed to
go to a garage and hook me car up to a computer. Common sense told me that they
were trying to make a dollar and that they had to be another way. Try using
your head from time to time and think before you speak.
When my car threw a code two weeks ago I looked up all the codes and sure as ****, the OBD1 codes did not match anything I could find for OBD2, which my car is. I tried the paperclip, and I was not getting the car to throw any codes I tried numerous ways and times, and it never did anything. I do know what I am talking about and I do have personal experience with this.
I stand by my statement that you CANNOT stick a paperclip in the sensor pinout and grab codes from an OBDII car. I have NEVER seen this done, and I have had numerous people including ASE Certified mechanics, with at least 10 years of certification under their belts, tell me that using a paperclip and turning the key is not going to happen. I don't care what you think, and I WILL discount your blatant disreguard for myself if I feel necessary. If you have a problem with me you DO NOT EMAIL ME EVER AGAIN.
This thread has gone way the hell off the topic and I am closing this bullcrap nonsense.
budnjax
Jul 26, 2014 05:46 PM
tgifford5
Jan 13, 2010 08:39 AM
coolaznboi112
Mar 21, 2008 06:27 PM
jgutka
Jun 9, 2007 01:24 PM
