Odd starting issue on practically new 07' Civic
Hello all! I have a tricky question that hopefully someone can provide some insight into regarding a starting issue I've been experiencing with my 2007 Civic EX Coupe. Often enough (at least once or twice a week), the car hesitates when I start it. I turn the key and it cranks a couple times, fires, and then "pop...pop..pop" but doesn't fire fully. Often, the car will finally start on its own but there have been a few times where I've had to give it some gas to get the engine running. Certainly not something I want to have to deal with, especially since this car is pretty much new. I've read a small bit on the issue from others but there doesn't appear to be much information out there since the car is so new. Also, I always turn the key to the on position and allow the fuel pump to kick in (saw something about "build up the pressure" in another post) before I crank the engine. I haven't taken the car to the dealer yet but plan on doing so soon. I LOVE the car but this problem is driving me nuts! I purchased the car brand new in September and it has around 2,600 miles on it now. Is there anything anyone can think of? I've checked the TSB's and I can't find anything. Any other owners that have had a similar problem like mine? If anyone has any information, I would really appreciate them sharing their experience! Thanks in advance!
-Matt
-Matt
If it doesn't happen all the time the dealer may not be able to do much for you. But it should start about instantly if you've let it prime like you describe. I don't know if an '07 has a fuel return system or just a single line to the injectors. The latter kind can "vapor lock" and cause symptoms like you describe, but it won't hurt anything.
bobehud
Dec 17, 2009 04:02 PM
bakertime
17
Jan 9, 2009 07:14 AM
my_hidden_romance
Aug 24, 2007 08:23 PM
just a sentra
Sep 26, 2006 08:30 PM
