Overheating ??
O.K, so I think I made a big mistake on assembly of the cam assembly. I put the head on, torqued then put the cam in and set it with up mark up, then put the rocker arm assy. on and set the valve lash on #1 and #4 cylinders. After that I remembered I was supposed to do it all then put the head on. Is there anyway I can set the next 2 cylinders without pulling the head off again ???? UPDATE---- I got impatient with myself and pulled the head off, now is it ok to use the same head gasket since its been fully torqued once allready ?
Well she is up and running great !! Just wanted to say thank you all for your help and patience with this thread. A pretty long one too. Once again thank you guys, espescially RonJ and 94civic... Thanks guys
permatex high temp thread sealer, comes in a little tube about 5 bucks, you can do a LOT of threads with that tube,best stuff i've ever used. It's good enough that it's approved for use in aircraft.
Ok so I went to check my timing and for any leaks as a final inspection and I got a leak. When removing the old parts, I took off the housing that the upper radiator hose connects to the head, when I put it back on I diddnt see a gasket so I smeared permatex on it, now its leaking pretty good. Is there a gasket for this and if not what should I do to fix
trebor_2005
May 19, 2006 01:40 AM
Civic95Blue
Jul 29, 2004 10:09 PM
