Please Help with CHARGING Problems!!!
Old Dec 3, 2009 | 08:13 AM
highland3's Avatar
Exclamation Please Help with CHARGING Problems!!!
I have bought a brand new battery and before that i bought a new altenator becuase my battery light came on and my car died. So, after doing all that and not finding what the problem is I'm totally lost. My speedometer and tripometer don't work also. My battery light is on and so is my engine light. It seems like my battery just isnt getting charged from my altenator. Is there any things i can check to see what the problem is????? Please Help
Old Dec 3, 2009 | 08:17 AM
Since you didn't say, let me guess it's a 1996, '97 or maybe '98 model.
If you have one of those, search for the "fuse 15" problem.
Old Dec 3, 2009 | 10:38 AM
highland3's Avatar
Default RE
sorry its a 2001 and i have check and replaced the fuse for the altenator just for saftey and that wasnt it either. I've tried everything obvious that i could think of and cant find the problem. I know its my altenator not charging and i have put three in since and still same problem.
Old Dec 3, 2009 | 04:36 PM
mundy5's Avatar
could it be a ground problem. double check that all the grounds are working properly. you might have a parasitic drain on your battery
Old Dec 3, 2009 | 05:24 PM
Power must reach the "I" pin of the alternator (one of the small wires) with the key on. Also you should have battery voltage on the large output wire at the alternator all the time.
The combination of losing power to the alternator, speed sensor, and oxygen sensors sounds like a problem with the engine harness.
Old Dec 3, 2009 | 07:54 PM
highland3's Avatar
Default RE
What could i do to check the engine harness?? I will check the voltage tommorrow on the altenator. Thanks for your input!
Old Dec 3, 2009 | 08:18 PM
you said you have a cel? get ur codes pulled and let us know what it said, i say check all ur grounds, battery to tranny, battery to frame, grounds on the thermostat housing.
ironhorse215
Apr 11, 2013 05:51 PM
drewefx
Jan 1, 2012 06:23 PM
ktm518
Apr 18, 2010 06:57 PM
rcvicdude
Nov 1, 2009 12:55 PM
loyolarobyn
Nov 13, 2004 11:54 AM
