Plug tube seal installation
Old Jun 17, 2007 | 02:01 PM
cpl rampage's Avatar
Default Plug tube seal installation
Well, i took the rubber seals that are in the valve cover, that seal around the spark plug tube. now, i am done cleaning and painting the valve cover. but it is next to imposable to get the new seals in. i have tried putting a socket that is the same diameter as the seals and either hammeringi them in, or pressign them in, but they always get a lil bit crooked, in the hole, and get stuck. i also tried heating the entire valce cover up in the oven.
Does anyone ahve any tricks on how to get them in? i am thinking about heating up the valve cover up in the oven for longer, the paint i used is good to 1200, but the clar coat is good to 500. i only heated it up a lil bit, and i know i can do a lil more, but how high can i go with out the seals melting once i put them in?
Old Jun 17, 2007 | 06:22 PM
Live_4it's Avatar
Default RE: Plug tube seal installation
I wouldn't go too hot, it shouldn't take much heat for those to become more flexible. I would put them in at a low heat 200 deg something like that and check on them every 5 min.
When I put a new valve covergasket in a honda accord,the gasketcame with new rubber rings and what not for the valve cover. They didn't take that much to get in so I dunno why your haveing such a problem....you sure they are the right ones for your engine?
you could try a little lube like vasoline, it will burn off and probably smell overtime but that could help u out.
Old Jun 18, 2007 | 03:11 AM
i heated up the valve cover with out the seals so the metal would expand, not heat the seals, although that might have worked. these arnt o rings tho, they are metal rings with rubber arround them. i did eventually get them in, i heeted up the valve cover so it would expand, and froze the seals so they would contractl. They were still really hard to put in, but i go them all in atleast most of the way. i will just have to wait and see if they seal correctly.
somecallmewalter
Jun 27, 2022 08:02 PM
gkitf16
Sep 23, 2009 07:33 PM
JJ Zettle
Mar 28, 2007 07:06 AM
olengrumpy
Dec 26, 2006 06:56 AM
Tonymore
Apr 30, 2006 10:34 PM
