power window and power mirror stopped working at same time
I noticed that the driver side power mirror had stopped working. When I started investigating I noticed that when I had the drivers side door open the power mirror adjuster would work. Looks like when the bundle of wires that power the driver side door are flexed (opening door) it made the connection. Here is where I made the mistake... with the door opened I moved the bundle of wires with my hand. I did not pull on the bundle , just simply moved it to test it's flexibility. After I did that I was never able to get the driver side power mirror to work with the door open again.... and worse the driver side power window was down at the time and it too stopped working.
Should I go ahead and replace the wiring harness that resides between the driver side door and car?
I have found several posts on this forum describing my issue. The others claim that some power device (mirror, window, lock) on the passenger door stopped working. The device would work with the door fully opened (flexing the harness between door and car). I am 99.9% sure that the passenger door-to-car wiring harness is my issue. Is this a one piece system that can be replaced? I am not really intrested in correcting the broken wires as in a matter of time they will break again or others will break... I prefer to replace harness if possible.
Tigal
Mar 8, 2012 01:56 PM
kev2809
13
Oct 18, 2009 11:21 AM
rcoursey
Aug 29, 2007 02:33 PM
