Problem with alarm and horn.
Old Nov 26, 2007 | 10:45 AM
kma's Avatar
kma
Default RE: Problem with alarm and horn.
Finally got around to it, turns out the clip for the horn was broken which I didn't notice (just glued it in). Also, after installing the jvc kd-avx2 I noticed that the alarm didn't have a problem with automatically rolling down the window anymore. So best guess is that there was some wire touching something in the radio bezel although I did check it before and there didn't seem to be any. Thanks again everyone for your help. Turns out it's also a good thing the alarm tech that installed the alarm never got to check it out (saved me a whole lot of money).....so THANKS A BUNCH!!!!
Old Nov 30, 2007 | 06:28 AM
kma's Avatar
kma
Ok so as you guys can see from my last post, I thought I got the problem sorted out with the alarm (turns out installing the radio had NOTHING to do with it). I usually have the windows set to lock from the master window switch but I just happened to not have this morning. Then WTF?!, I noticed that the SAME problem happened again with the alarm being disarmed and the window rolling down and then unlocking the driver side door from the switch on the inside it rolls down some more. So now again I'm like WTF? I disconnected the alarm's module box and I'm like WTF again cuz it's STILL happening. So I locked the switch back and tried again and nothing happens. Could it be that because the master switch is bad it's causing a problem of some sorts? I thought it would have only prevented the other windows from like going up or down or something but it's actually messing with the alarm so now I'm at the[sm=alcoholic.gif] feeling. Can someone PLEASE help me!!!!!?????
av3rag3am3rican
Oct 6, 2007 08:33 PM
BruceK
Aug 4, 2007 09:15 AM
dapasda
15
Jun 21, 2007 07:10 PM
remy
Jun 1, 2007 12:37 PM
hcivics
Feb 11, 2007 12:32 AM
