"pulling" gauges- 01 ex coupe
Old Mar 7, 2010 | 12:38 AM
frankenstein616's Avatar
Default "pulling" gauges- 01 ex coupe
when my car is running, whether it be at idle or at 7000 rpm, my gauges "pulse." this is kind of annoying because i just did the big three wiring upgrade, and have just recently bought the car. has anyone else run into this problem. also while i am on the topic of gauges, i have both the check engine light and maint. required lights illuminated on my dash.
Old Mar 7, 2010 | 05:05 AM
You're saying that all the lights on the car pulse bright and dim, or just something is strange with the gauges?
The maintenance required light is merely based on a timer that you can reset (after doing the maintenance). I think it is reset by holding the trip odometer button down, read the owner's manual for more details.
To find out why the check engine light is on you will need an OBDII scanner, or you can take the car to a consumer auto parts store (Advance, O'reilley, Checker, etc.) and they will scan it for you for free.
Old Mar 7, 2010 | 06:30 AM
When you take the car to an auto parts store to have them pull the CEL codes, also have them test the charging system. The voltage regulator in the alternator may be faulty.
Old Mar 7, 2010 | 05:24 PM
thank you i did go to the parts store and they tested it and it came back as:
cyl 1 misfire
cyl 2 misfire
cyl 3 misfire
cyl 4 misfire
random misfire
inconsistant fire order
faulty plug in all cyl
Old Mar 7, 2010 | 05:27 PM
Check the fuel pressure.
addiction2bass
Mar 4, 2011 04:14 PM
christinav09
May 29, 2010 07:59 PM
KP1972
Mar 18, 2010 04:19 PM
inthezoneac
Dec 27, 2008 11:17 AM
logeoff
Aug 18, 2008 10:23 AM
