Puzzling Electrical Gremlins
Hopeing to find some help here
We have an 89 crx (dx) with some strange electrical problems. I'm not sure if it's just one or a whole host of problems...
Problem 1: Headlights go dim and bright at night very randomly. - We're going to try cleaning the grounds first otherwise replace the alternator. The heater fans speed up when the light goes bright too
Problem 2: This is the weird one, the seatbelt light and clock flash continuously at what appears to be a steady speed however they don't both flash at the same time, the seatbelt and clockflash out of sync with each other. What could cause this?
Problem 3: Clock reset's to 1:00 every time we shut the car off... (minor minor issue)
Any chance that these are all related? Any suggestions on what is caushing which problems?
The GF swears it all happend one day when she was fiddling with the lighter plugging in a cell phone. When she yanked the cell phone charger out the whole lighter assembly flew out with it...
We have an 89 crx (dx) with some strange electrical problems. I'm not sure if it's just one or a whole host of problems...Problem 1: Headlights go dim and bright at night very randomly. - We're going to try cleaning the grounds first otherwise replace the alternator. The heater fans speed up when the light goes bright too
Solving this problem may fix the others. The alternator is likely bad. Before you replace, however, check whether the alternator belt is loose or slipping (glazed or oil contaminated). In addition, also go ahead and clean the battery connectors and terminals, as well as the battery ground wire attached to the engine bay frame.
I concur with RonJ's analysis. mine did the exact same thing for yrs until my alt got so bad, it no longer charged the battery. don't wait that long. what you can do is take out the alt and have it bench tested at an auto parts store. they do this for free.
miester
Jul 4, 2009 06:54 PM
fierychick
Jan 29, 2009 11:23 AM
Norman_x
Dec 8, 2004 02:09 PM
vk4bcp
Jul 6, 2004 03:31 PM
