pvc valve
Old Aug 3, 2006 | 06:37 PM
silvercivicex98's Avatar
Default pvc valve
where is the pvc valve and how do i change this?
also ive never changed the rotor either, is this hard in my civic?
Old Aug 3, 2006 | 07:11 PM
tripod's Avatar
Default RE: pvc valve
the pcv valve is in the back under the throttlebody. kind of a pain to change unless you have small arms. for rotor i'm assuming the distributor rotor. it easy. if your concerned take a digital pic before. it's best to change the cap as well.
Old Aug 3, 2006 | 07:19 PM
pWnEdU's Avatar
Changing the cap and rotor along with plugs wires and PCV (NOT PVC) is part of a standard tune up.
Changing the cap and rotor are pretty much fool proof.
Old Aug 3, 2006 | 11:23 PM
fglaustin's Avatar
1 thing about the rotor - if the same as 1988, there is a small screw thru it. may have to crank the engine just a little to bring it around. most cars i worked on do not have that - only need to pull it off - not possible here.
Civic Jordan
May 7, 2007 06:59 PM
roblinxs011087
Mar 30, 2007 07:44 PM
civicexracer
Nov 9, 2005 05:41 PM
mill$civic
Oct 31, 2005 06:25 PM
jlh911
Jun 30, 2005 09:52 PM
