Question on Distributor
Old Dec 10, 2007 | 11:32 AM
nociv1's Avatar
Default Question on Distributor
On the 97 D16 Y8 motor inside the distributor is a TDC sensor. Is there any way to test that sensor to make sure its good?
Old Dec 10, 2007 | 12:36 PM
Default RE: Question on Distributor
Typically, if the sensor is bad, your Check Engine Light should be ON, and you should retrieve a code indicating a fault with the TDC circuit.
Old Jan 12, 2008 | 12:18 PM
mista226's Avatar
I have a 98 and my sensor went a few months ago. I just had it replaced yesterday and was told the sensor is behind the timing belt shield. So they did a needed timing belt/water pump change.
Funny thing is now, the CEL is back on with a P1361 code. WTH?!?!?
Old Jan 12, 2008 | 12:25 PM
The top dead center (TDC) sensor is inside of the distributor. If the TDC sensor is bad (possibly indicated by P1361), you need to replace the entire distributor assembly.
The crankshaft speed fluctuation (CKF) sensor is behind the timing belt shield.
Old Jan 12, 2008 | 04:15 PM
mista226's Avatar
Thank you for the clarification...another question for you, what type of distributor do I have?? I'm trying to source one so I can put it in, but there are two kinds showing up.
Old Jan 12, 2008 | 04:25 PM
The distributor should match with the engine. The picture shows where to find the number for your engine type.
Old Jan 13, 2008 | 05:01 AM
mista226's Avatar
Thank you so much for the info...very informative board here.
seaton05261979
May 24, 2007 01:23 PM
ic892003
Mar 4, 2007 05:36 PM
Xemu
Aug 24, 2006 11:37 PM
tarboroheel1
May 11, 2006 06:33 PM
newvx
Mar 30, 2006 10:34 PM
