question w/ transmission
Old Aug 8, 2008 | 07:52 PM
rhoads's Avatar
Default question w/ transmission
ok i accidentally took a turn at 50 mph and the tires screeched and i accidentally hit the gears and shifted it to neutral while i was turning. after i stopped i realized i was in neutral and just got in drive. did i do any damage to anything?
Old Aug 8, 2008 | 10:54 PM
neutral drops aren't good for an automatic transmission, but i don't think just one would cause any problems. i'm sure your transmisson is fine.
what kind of turn were you taking, anyway? dang
Old Aug 9, 2008 | 06:46 AM
rhoads's Avatar
it wasnt really a neutral drop because after i got into the parking lot out of the turn i realized it was in neutral and stopped before i shifted it to drive....i forgot to say that
Old Aug 9, 2008 | 06:54 AM
You're fine. You just made a normal start from stopped. The important thing is not to shift gears with the engine revved up.
A neutral drop is when someone tries to make a fast start in a drag race by revving the engine in neutral and then "dropping" into gear. They won't be doing that for very long.
Old Aug 9, 2008 | 11:36 AM
macbeth18288's Avatar
How do you accidentally take a turn at 50?
Old Aug 9, 2008 | 11:42 AM
lol, i had always thought a neutral drop was if you bump it into neutral while driving (idk why someone would do this... maybe to rev their engine at you? idk). lol. what you said makes more sense though, mk378.
Old Aug 10, 2008 | 12:17 PM
mundy5's Avatar
i think some hypermilers might do what you said trustdestruction to save on fuel though most seem to do this with hybrids.
Old Aug 18, 2008 | 05:28 PM
jbum's Avatar
is it really a bad thing to shift to neutral on an auto tranny? if so, why?
Old Aug 18, 2008 | 05:49 PM
SilverSedan's Avatar
No, in fact when stopping on snow/ice you have more control by shifting into neutral when braking. The bad part is if you have the engine revved up and shift it back into drive. The higher the RPMs the worse it is for your tranny.
Old Aug 18, 2008 | 05:51 PM
jbum's Avatar
ok... that's what i thought. I just wanted to see if what the previous poster said was right. It's essentially like a manual clutch. You can burn the clutch at high revs if you don't match revs. Same thing for auto. I get it.
Thanks.
dbarwi1
Feb 25, 2007 02:05 AM
98civex
16
Feb 18, 2007 01:33 PM
CivicNooby00
Feb 11, 2007 07:05 PM
mayder
EK Swaps
Dec 6, 2006 12:09 PM
jad1217
Aug 4, 2006 11:14 AM
