quick question??
Old Oct 29, 2007 | 05:47 PM
ks00civ's Avatar
Default quick question??
ok so there's this little vibration that happens under my car everytime i start going in 1 and through the beginning of 2. i think it might be something with my exhaust because it stops once i start going about 20 like half way through 2. can anyone help me as to what this might be??thanks!
Old Oct 29, 2007 | 06:08 PM
Default RE: quick question??
I don't know whether this will help, but my 1997 Civic DX had a very similar problem that turned out to be a loose exhaust heat shield located near the catalytic converter.
Old Oct 29, 2007 | 06:26 PM
ks00civ's Avatar
oh really?? was that hard to replace or what?
Old Oct 29, 2007 | 06:29 PM
95civic1.6l's Avatar
check your heat shields. check all of them. If that isn't it then let us know. You can take a long screwdriver to bend them so they won't hit your exhaust
Old Oct 29, 2007 | 06:39 PM
Replacing/fixing is very easy. Raise front of car on jack stands. Easy access and visibility from underside. The heat shield covering exhaust pipe A was my problem (see picture). Check shield for any wiggle or looseness. Even a small amount can be amplified by engine vibrations. The shield is held in by two bolts. You may be able to fix looseness without replacing.
[IMG]local://upfiles/25538/A0329786D0B34CC4BFE1B7CE921684C1.jpg[/IMG]
Old Oct 29, 2007 | 11:40 PM
ks00civ's Avatar
oh ok sweet thanks alot guys! ill check that out tomorrow and see if thats what it is. thanks again!
Old Oct 30, 2007 | 03:14 AM
just pull em off, won't hurt anything
THE_CRIPPLER
Dec 6, 2005 08:26 AM
scottex
Jul 18, 2005 04:58 PM
fastman90
Jun 26, 2005 12:59 PM
Smeghead009
May 31, 2005 12:02 AM
02CivicEX
May 4, 2005 07:03 PM
