Radiator fan control
I need some control advice for my 98 Civic EX. The radiator fan switch works but according to all the books, the fan should come on when the AC is on regardless of temp switch. After looking at the wiring diagram, I see that the temp switch controls the ground. That same green wire goes to the PCM. How does the AC turn on the fan? Any advise will help. Thanks
Unlike most cars, the 92-00 Civics have a side by side placement of the radiator and A/C condenser as two independent units each with their own air flow. Thus the A/C operation is independent of the radiator fan. Only the condenser fan should come on when the A/C is on. The radiator fan is controlled only by the coolant temperature sensed by the switch on the thermostat housing.
The 01 has the more conventional arrangement of a full-width condenser in front of the radiator. So both fans should come on with the A/C to cool the condenser. Does the engine overheat because the fans don't run other times?
On another note, once again while driving 70mph my TEMP guage dropped to COLD , as if the car were off, and hung there for 40 miles till I pulled in the parking lot of my gym and shut the car off. Later, I drove home and the TEMP read normal at slightly lower than 3:00 on the dial. Both radiator hoses indicate hot water is flowing. I don't think it's the guage..probably the ECT sensor. I don't think a stuck thermostat would make the car read COLD on a 85 degree Florida afternoon at 70 mph.
anivast999
May 14, 2011 06:15 PM
