Radio and Heat not working
Old Dec 22, 2007 | 03:52 AM
iduno's Avatar
Default Radio and Heat not working
I recently repaired the combo switch for the dash/rear brake lights. No problem. No more getting pulled over! The next day the radio and the heat stopped working - simultaneously. They had been working prior. Where do I start to dx - other than fuses ('90 Civix DX)? Thanks.
Old Dec 22, 2007 | 05:43 AM
Default RE: Radio and Heat not working
It' s difficult to see any connection to the combination switch work that you did (pictures). Check whether fuses 12 (15A) (Stereo) and 19 (30A) (Blower) (Auxiliary fuse holder) are blown.
Clarification: When you say the heater doesn't work, do you mean that the blower doesn't work or that the blower works but blows only cold air?
Old Dec 22, 2007 | 06:30 AM
iduno's Avatar
Clarification: When you say the heater doesn't work, do you mean that the blower doesn't work or that the blower works but blows only cold air? The blower doesn't turn on. There are five speeds to it, including OFF. I did check the fuses; they appear ok. Any thoughts?
Old Dec 22, 2007 | 06:40 AM
Check the rear connectors for radio and blower motor and switch. Bad blower motor or fan switch or corresponding wiring? Dead radio?
forwardlookguy
Oct 10, 2012 06:27 PM
mck519138
Feb 25, 2010 11:42 AM
gunaa
Oct 22, 2009 11:36 AM
fbbyrd
Aug 12, 2008 05:16 PM
chrisroug
Oct 2, 2006 11:36 AM
