Really need help, guys (99 civ won't start)
Old Jul 29, 2010 | 01:16 PM
dqcivic's Avatar
Default Really need help, guys (99 civ won't start)
Okay, so here's the deal.
Last Saturday the car ('99 Honda Civic DX Auto) was running fine. I haven't noticed a thing wrong. After I got home, I turned off the car, and five minutes later, it wouldn't start, the engine wouldn't even crank (again, NOTHING was wrong with the car beforehand). So after much research, I replaced the battery (didn't help) and the starter & solenoid (didn't help, either). Before I switched the starter, the car made a clicking sound when I turned the key (sound of a bad starter). After I replaced the starter, it still makes a clicking sound, it's just a LOT more subtle. All the fuses and wiring is fine, I had a friend-mechanic check everything. The ignition switch is fine (the solenoid wants to turn, but it doesn't). To check if it was the alternator, I tried jumping the car, but to no avail.
So I'm all out of ideas. Mech-friend says that it just might be that the engine seized, which would mean that my car is done for quite a while. Any other ideas? I could really use the help.
Oh, and there's this little blinking red light where the cruise control would be in other Civ models of the same year (to the left of the steering column). I don't have an owner's manual, so I have no idea what that blinking red light is trying to tell me.
Old Jul 29, 2010 | 02:05 PM
With the tranny in neutral, try to turn the engine by hand from the crank pulley bolt.
Old Jul 29, 2010 | 02:13 PM
dqcivic's Avatar
Thanks for the tip. Can you explain to me how to do that? I'm not at all car-savvy, I'm learning as I go.
Old Jul 29, 2010 | 02:17 PM
The crank pulley is the big pulley on the bottom driver's side of the engine that drives the alternator, etc. belts. Put a socket wrench on the bolt in the center, and with the key OFF, try to turn it counterclockwise.
If you find the engine is not seized, you'll need to get a voltmeter and measure around the circuit to see where the voltage is being lost. Another test you can do is turn the headlights on then turn the key trying to start and see if the lights stay on.
Old Jul 29, 2010 | 02:22 PM
dqcivic's Avatar
Alright, thanks a lot. I'll come back with results.
Old Jul 29, 2010 | 02:31 PM
dqcivic's Avatar
I'm sorry, guys, I have another few questions. How far do I turn the bolt? When should I have someone try to start the car? How do I absolutely know that the engine has seized? Thanks for the help, I appreciate it.
Old Jul 29, 2010 | 02:56 PM
If the engine is seized, you will be unable to turn the crank pulley.
Old Jul 29, 2010 | 03:29 PM
dqcivic's Avatar
Oh, ok. Thanks again.
Old Jul 29, 2010 | 03:56 PM
Leave the key OFF while turning the engine by hand! You can get hurt if it tries to turn by itself while you're holding the wrench.
krystencivic99
Jan 21, 2008 12:09 PM
s0ulj3r
Dec 25, 2007 07:03 PM
Fiasco
Aug 3, 2007 09:23 AM
Partizan
Jan 25, 2007 09:13 PM
apexi_89
Jul 28, 2006 11:43 PM
