Really weak cranks than before
Old Sep 26, 2011 | 12:52 PM
Quasars's Avatar
Unhappy Really weak cranks than before
After changing the fuel pump, my car's cranks are noticebly weaker than before. I mean, it cranks slow and if I hold the key, it will die out in 5 seconds. What could be the outcome of this? sparks plugs/wires? The distributor rotor spins really slowly, should the distributor be replaced? Any info is much appreciated.
Old Sep 26, 2011 | 02:44 PM
maachan513's Avatar
Check electrolyte level and make sure it is proper on each cell if you have conventional battery.
Charge battery if you have a charger. Perform load test of the battery a few hours after the charge is complete. Or take it to an auto parts store where can perform that test for you.
This would be the first thing I would do.
Old Sep 30, 2011 | 01:56 PM
Quasars's Avatar
For future references, the ICM (Ignition Control Module)had gone bad in distributor cap. Reason why it wouldn't start up. Wasn't the fuel pump or starter.
Old Oct 1, 2011 | 05:21 AM
maachan513's Avatar
I thought "slow cranking" was the issue.
briceman124
Jan 4, 2012 07:50 AM
Damir Poljak
May 10, 2011 11:09 PM
krystencivic99
Jan 21, 2008 12:09 PM
Partizan
Jan 25, 2007 09:13 PM
vv1980
Feb 4, 2005 01:30 AM
