Rear LCA bolt snapped...Now what??
Old Nov 9, 2007 | 03:30 PM
chase07's Avatar
Default Rear LCA bolt snapped...Now what??
I started to put new rear shocks on today and when I tried to remove the bolt that holds the lower control arm to the trailing arm it snapped about an inch below the head. I have searched the site about this and it seems to be a common problem. How am I going to get this bolt out? Can the dealer do it? I really need my car for work Monday. Any help with this would be greatly appreciated. Thanks in advance.
Old Nov 9, 2007 | 04:36 PM
riceburner700's Avatar
Default RE: Rear LCA bolt snapped...Now what??
you are gonna have to drill the bolt out and retap the threads and run a new bolt in
Old Nov 9, 2007 | 04:39 PM
chase07's Avatar
Would I be better off taking it to the stealer?
Old Nov 9, 2007 | 04:52 PM
Take a trip to your local hardware store and look for bolt extraction tools. I am pretty sure that you will find a tool where you drill a hole into the shaft of the broken bolt and then remove it using a reverse thread screw. Some penetrating oil would help with the latter process. Good luck!
tsmith944
May 11, 2011 08:27 PM
SiPex
Jul 23, 2010 06:04 AM
Scott53092
Sep 29, 2009 05:55 PM
croninc
Jun 4, 2009 07:40 PM
snosurfa7
13
May 18, 2007 02:08 PM
