Replacing A/C Heater control panel
Hello!
Just wondering if anyone of you had recently replaced their faulty A/C heater control panel, i want to know how to pull out the panel without hurting the dash. Info greatly appreciated. Thanks.
jimboy
jimboy
That's an easy one... Well, if you want good informations, you will need to give us your car year and model but anyway any car dash is pretty straightforward, remove the screws, unclip the dash parts, change the controls, put everything back together... just take it SLOWLY cause sometime (ok ALWAYS) you miss a screw or a clip and the parts won't come off and then you just pull and bam you crack the dash... and then your like.. **** there was a screw right there...
Take the outer trim panel off, remove the radio, then reach up thru where the radio was and remove the screws holding the panel in. I think there are 3, two in front and one in back. They're hard to find because they're up in recesses. The lighter colored screws just hold the panel together, removing them won't help take it out.
new_2_civics
Apr 1, 2010 02:37 AM
tgs
Mar 28, 2010 07:12 PM
PredatorCoder
Aug 15, 2005 05:43 PM
