Rotors?
Old Jan 14, 2006 | 10:16 AM
97CivicEX's Avatar
Default RE: Rotors?
ORIGINAL: AgentofDarkness
And how good is set of $20.00 rotors going to be?
Just for the record, I was not suggesting the 20 dollar rotor. I was mearly pointing out that there were rotors out there for a cheap price close to the cost of resurfacing. Once again, my suggestions on brake parts are OEM. That is for both rotors and brake pads. That set up is not prone to warp and will last the longest of the other choices.
Old Jan 15, 2006 | 01:55 PM
Kappa22's Avatar
Default RE: Rotors?
If you're running metal or ceramic-metal pads, you should probably be running some nicer rotors than OE anyway.
Old Jan 15, 2006 | 02:10 PM
AgentofDarkness's Avatar
Default RE: Rotors?
Metal pads are gonna eat up a rotor like a fat kid on cake. To me, those are overkill when it comes to a street driven car.
Old Jan 15, 2006 | 10:30 PM
97CivicEX's Avatar
Default RE: Rotors?
X2
Old Jan 16, 2006 | 09:10 AM
boatboatboat's Avatar
Default RE: Rotors?
ORIGINAL: boatboatboat
keep in mind that ceramic pads DO NOT STOP WELL....... what they do is create less brake dust, and last longer. People use ceramic pads if they don't want to spend 10 min cleaning high dollar rims every day. For track use a soft compound pad is best Hawk makes a very low cost pad that works quite well.
As far as rotars, 90% of the people who do DE classes or road course weekends, use low cost OEM rotors. They are viewed as throw away items after 2-3 weekends of tracking. I have a set of bling bling drilled and slotted rotars and ceramic pads I use for DD/Show use, but when it's time to stop fast, it's time to break out the soft pads, OEM rotars, and cheap/light rims.
I can get 4 OEM rotars for a c-5 for less then 140 bucks total, I can't imagine a civic set of rotars cost more then 100 bucks for all 4.
The cheapest way to improve your breaking is via a high quality brake fluid and SS lines. Those two items will do wonders to reduce brake fade.
I would go with ceramic pads. I've always heard good things about them. And how good is set of $20.00 rotors going to be? If I was gonna buy new rotors, i would spend some extra money to buy some really good rotors instead of buying cheap crap that might crack and warp easier because the material is not good. You get what you pay for.
[/quote]
Booshanky
Sep 3, 2010 03:19 AM
mchiles
Apr 26, 2005 08:22 AM
mchiles
Apr 26, 2005 08:18 AM
StifflersMom
Jan 25, 2005 04:34 PM
Steve2210
Nov 25, 2004 09:39 PM
