Rough Idle
so i got it to run bad again, shut it off and found that plug #1 or #4 farthest from the distributor was fouled. I then noticed there was like no gap whatsoever so i bought a replacement and am gonna check it momentarily.
pulled the plug and the same thing is happening.
I didnt let it cool long and a light smoke came out from the plug hole. This only happens when it reaches temperature first though.
I think its like a slight head gasket leak or something.
Compression test reads 180-185 across all four cylinders but on the cylinder that had the foul when running bad shoots oil out the plug tube! what does this mean if the compression is good?
