Rough Idling on 99 Civic CX
Old Nov 14, 2011 | 12:39 PM
ashlauren's Avatar
Default Rough Idling on 99 Civic CX
The car only idles rough, once accelerating it's fine.
Recent replacements: tune up, thermostat, and distributor.
I'm thinking about cleaning the IACV? Any other ideas?
Check engine light is not on, and otherwise the car drives fine.
Old Nov 14, 2011 | 01:14 PM
Welcome to the forum ashlauren.
When did these symptoms begin? After or before you installed these parts?
If after wards, I would check to make sure your timing is correct. If before, I would suggest to check the spark plugs and wires (if not done in the tune up which you stated), and clean our your IACV and let us know what happens.
Old Nov 15, 2011 | 10:37 AM
ashlauren's Avatar
In the tune-up, the timing was checked, and all new plugs and wires.
Also, the car does not always have the rough idle, only occasionally, about once/day (I drive roughly 65 miles per day, mon-fri).
Old Nov 16, 2011 | 06:43 AM
AZipper's Avatar
I'm having similar problems. Once I accelerate there is no roughness. The car idles rough. I have considered replacing the distributor. I believe that it may have somethin to do with timing because it also skips sometimes when driving.. not sure. I definitely need to get a diag.
Old Nov 16, 2011 | 08:19 AM
Gave you guys cleaned out your IACV? Just wondering.
xhasti
Sep 8, 2014 03:05 AM
bignascarfan12
Mar 3, 2011 06:50 PM
Stumasters
Jan 20, 2008 12:58 PM
Losthate
Aug 29, 2006 10:00 PM
bleedhondos
Dec 18, 2005 03:29 PM
