rpm drop, engine shakin
Old Jul 17, 2005 | 01:11 PM
vmf's Avatar
vmf
Default rpm drop, engine shakin
hey guys, got some weird symtpoms this morning, when i put the car into drive rpms drop and whole car starts shaking, i put it in neutral and i got the same thing, reverse does not seem to cause the rpm drops, even when i put it in park i still get it. i would think that it might be the burned coil but then the problem is not permanent, this rpm drop does not happen every time i start the car. could humidity cause this? i dont think any changes in perfomance.
Old Jul 19, 2005 | 07:34 PM
vmf's Avatar
vmf
Default RE: rpm drop, engine shakin
i think i found out the reason why the i'm gettin the rpm drops, i disconnected the battery and now computer in the learning mode, with time during the day i was gettin less and less of those. i will post the final resolution in few days.
Old Jul 19, 2005 | 11:08 PM
Omen68's Avatar
Good luck VMF!
Lets us know your final resolution.
Old Jul 20, 2005 | 08:53 PM
vmf's Avatar
vmf
drove the car today, with and without AC, rpms are back to normal!
so it was an ECU learning mode
Old Jul 23, 2005 | 12:30 AM
Novahawk13's Avatar
i have kind of the same problem, what do you mean with learning mode and how do i know if its in it and how do i get it out of learning mode if its in it?
Old Jul 23, 2005 | 03:36 PM
97CivicEX's Avatar
The ECU is always in learning mode. The problem is that the settings are so far off the default ones that it takes the computer a little longer to learn when reset.
Novahawk, if you reset the ECU(by either removing the fuse or the battery) it will take a while for the computer to "learn" the optimum settings for proper operation.
Old Jul 25, 2005 | 04:11 PM
AgentofDarkness's Avatar
What was the problem in the first place?
Old Jul 25, 2005 | 09:16 PM
vmf's Avatar
vmf
learning mode, ecu drops to defaults when u disconnect the battery, after few drives everything went back to normal
mhouseman
15
Aug 1, 2014 04:36 PM
biocpu
Jun 29, 2007 11:29 PM
addiction2bass
22
Jun 21, 2007 08:16 AM
Motor35
Oct 6, 2006 11:13 PM
02CivicEX
Mar 6, 2005 10:45 AM
