Setting Timng Tension on '03 Civic LX
I just replaced a timing belt on a 2003 SOHC 1.7 Civic LX. The manual talked about using a 3mm pin to hold the timing belt tensioner in place while the new belt was installed. Instead I unhooked the spring on the tensioner, installed the new belt, loosened the tensioner pulley bolt and reinstalled the spring. I then rotated the crank pulley several revolutions and tightened the tensioner pulley bolt. All the timing marks are lined up.
Is this the correct way to set the tension? Thanks.
redzthredz
Dec 22, 2011 09:02 AM
1stHonda
Oct 20, 2010 12:42 PM
hidden
Mar 14, 2007 11:28 AM
