short shifter install question
I was reading over the diy for the short shifter and in this pic it shows these broken rubber grommets at the base of the shifter, I was just wondering if you need those when you put in the new short shifter or if you can just bolt the shifter onto the linkage without them
thanks
http://img.photobucket.com/albums/v2...g?t=1207225229
thanks
i would keep them if the outter ring is peeled back then its not to bad thats just the outter... the inner rubber is what mainly counts. definatly put them back in.
and i would also sugest before lowering the car get into the car and slap the shifter around thru the gears and make sure there is no binding.
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
heathershonda
12
May 10, 2007 07:18 AM
ELECTRON BLUE 2000
Apr 18, 2007 11:00 AM
05CivicLX
Jun 4, 2005 12:46 PM
cnote
Apr 18, 2005 12:37 PM
