silver oil
Old Sep 25, 2007 | 04:24 PM
CYPH3R's Avatar
Default silver oil
i am rebuilding my 1.6l sohc motor after replacing the oil pump and cam bearings and a full ring set, i noticed i have silver swirls in my oil. any ideas?
Old Sep 25, 2007 | 04:47 PM
foress_89's Avatar
Default RE: silver oil
like metal pieces or like liquid?
Old Sep 26, 2007 | 04:50 PM
CYPH3R's Avatar
grainy liquid
Old Sep 26, 2007 | 04:53 PM
ryank327's Avatar
How many miles?Either way if its grainy thats not good. Good thing your rebuilding it. Pick up a magnetic oil drain plugalso, the best 15 bucks you could spend on your car!
Old Sep 26, 2007 | 04:55 PM
Marty's Avatar
it is metal shavings
that is why I have allways bought magnetic oil drain plugs for all my cars because it gives you advance warning plus it dont let the **** back into your system
Old Sep 27, 2007 | 05:24 AM
shsucivic's Avatar
I could be that you have some water or fuel in the oil causing the oil to look milky or grayish
Old Sep 27, 2007 | 05:19 PM
CYPH3R's Avatar
well i was guessing it was metal just didnt know where it came from, as it turns out it was the connecting rod bearings turns someone had milled the crank and didnt tell me about it so it had the wrong sizr bearings. so now im putting in a new crank...... yay now im in this motor for more than it would have cost for a reman
Old Sep 29, 2007 | 11:28 AM
civicpimpinsc's Avatar
ouch... i noticed something like that in mine when i changed my oil this time.... I have been doing a lot more idle time than usual, and went over on the oil change because living in an apartment I can't work on it there, and my work schedule really doesn't leave much time... man i hope mine isn't a rod bearing... it's my daily driver...
I was thinking about getting one of those "filter mags" it's a magnet that you put on your oil filter, basically would do the same thing as the magnetic plug, but you wouldn't see what was picked up that would be the down side to that...
Old Sep 29, 2007 | 02:07 PM
foress_89's Avatar
I heard they're real good these magnets.. Just get boths! And.. You can rip your filter off to check what got inside...
Old Sep 29, 2007 | 04:37 PM
CYPH3R's Avatar
yeaaaaa, so i rebuilt the motor, and i cant get it on the transmission. all the bolts are in so its aligner perfectly but i cant line up the splines
oilltd
Jun 10, 2008 04:06 PM
artrusli
Dec 1, 2004 02:59 AM
JMphskal85
Oct 27, 2004 05:28 AM
BOTLFED98
Jul 23, 2004 02:41 PM
