SMOG test failed
Hi All,
I moved in from NJ to CA couple of weeks back and I took my vehicle for a smog test and it failed. I have a 2001 honda civic lx with aem intake, dc sports header and an aftermarket catalytic converter with dual exhaust.. please help...
Any help would be really appreciated..
Thank you all
Viswa
Thank you all
Viswa
thanks for your repsonse..well the guy who did smog said the O2 sensor supposed to be one in front of the cat and the other one back of the cat where as in my xase both the sensors are i guess infront of the cat. I dont have a stock cat, the reason being is my old cat life was over and i had to replace the cat and the stock cat costed me way over than the performance cat. is there any way i could pass my test with the current setup w/o doing any change..?
thanks for your help
It's failing because at the very least, it is obviously modified. I think you'd need to have the second sensor after the cat or it's going to set the CEL. Maybe if it looks right and the stuff coming out of the cat satisfies the sensor so the light stays off, it'll pass.
Lazzii
Sep 26, 2013 03:37 PM
brdude
12
Apr 6, 2008 03:46 PM
m0rgansciv
Jan 18, 2008 05:39 AM
