Something squeaks when I close passenger door
Old Apr 26, 2008 | 03:16 PM
inthezoneac's Avatar
Default Something squeaks when I close passenger door
I drive a 00 civic ex coupe and recently had a sound system installed. We had to unmount the doors to drill a hole for the new wiring and now when I close the passenger door it squeaks right when it shuts. It actually sounds like the same squeak I assume my struts were doing when I drive on dry days or when I hit little bumps in the road.
what could cause that problem?
Old Apr 26, 2008 | 03:20 PM
Default RE: Something squeaks when I close passenger door
Check the edge of your fender where it matches up with the door... your door might be scraping the fender when you open/close it. When the door just barely scrapes the fender, it makes a squeaking sound.
Old Apr 26, 2008 | 03:25 PM
it's not a rubbing sound, but like the same squeak on an old suspension.
Old Apr 26, 2008 | 04:30 PM
mundy5's Avatar
did he lube the hinge? i use wd40 myself
Old Apr 26, 2008 | 05:37 PM
i can open it fine without any noise, but the second it closes against the car it makes a squeaky noise. It sounds like my suspension over a bump, which is weird because it sounds exactly the same.
briceman124
Aug 29, 2011 07:16 AM
reaper2022
Sep 5, 2007 02:43 PM
NickF829
Mar 13, 2007 08:25 AM
baker7598
Oct 31, 2006 03:06 PM
Jas
May 3, 2006 10:15 PM
