Spark from coil, none from cap
Old Apr 20, 2008 | 08:41 PM
dnascuba's Avatar
Default Spark from coil, none from cap
Hello all,
I am trying to help my friend with his 93 Civic. The car died on him the other night, and I have checked most of the items suggested on the forum. What is interesting, is that if I remove the dist cap and use a spark plug tester to ground the coil, I get a nice spark when cranking the engine. When the cap is replaced, I get no spark out of the cap. I checked to make sure the spring on the end of the coil is touching, as well as the rotor to button by using paint to matchmark. The coil is def putting out spark, and the resistance between the coil points is less than an ohm. I just cant figure out why its not making it through the cap. The cap and rotor are new, as well as the plugs.
Any help or insight would be appreciated.
Old Apr 20, 2008 | 11:23 PM
Big EZ's Avatar
Default RE: Spark from coil, none from cap
i had a friend that had this problem on her camaro and it turned out to be a broken rotor button. i know it sounds wierd to break one, but still its worth it to check. on hers the whole assembly wasnt broken just the tab that crosses the points inside the cap.
Old Apr 20, 2008 | 11:25 PM
Big EZ's Avatar
guess i should have finished reading your post about the new cap and rotor. still i would double check it. could even be the tab is bent and not broken.
Old Apr 21, 2008 | 05:58 AM
+1 on having a short in the rotor. If there's a crack in the plastic the sparks will jump from the contact in the rotor to the shaft. Just because a part is new doesn't mean it is good.
Old Apr 23, 2008 | 01:04 AM
TheJGB3's Avatar
Return the cap and rotor (since they're new they should be under warranty) and get new ones.
Dirtyi1178
Dec 14, 2007 07:47 PM
khanselman
Nov 10, 2006 02:49 PM
Cam
Sep 7, 2006 12:01 PM
Street Sniper
Jul 21, 2005 10:05 PM
