Speedo Cluster light issue
Old Oct 7, 2012 | 02:25 AM
91DxRob's Avatar
Default Speedo Cluster light issue
Hey all, can't seem to catch a break with my Civic hehe
Now occasionally when I'm driving at night the lights so i can see the speedometer and all that in the cluster wont turn on at all, or they'll flicker and I'll have to hit the top of the dash a few times real good to get it to stay on and not flicker... Is this a short somewhere in the wiring that will require a replacement, or could it be just a fuse going bad, and if so, which fuse would it be?
Thanks!
Old Oct 7, 2012 | 06:10 AM
Do the ones on the heater control panel do the same thing? If so it's likely the dimmer control.
Old Oct 8, 2012 | 02:36 PM
91DxRob's Avatar
Nope heater control ones work fine.... Fuse?
Old Oct 8, 2012 | 03:02 PM
No, they're all on the same fuse.
There must be a loose connection near or in the cluster then. You can take the "hood" trim off of the "back" of the cluster (the side facing the front of the car) and wiggle the plugs.
Old Oct 9, 2012 | 07:05 AM
91DxRob's Avatar
Ooh is that piece easy to remove?
Old Oct 9, 2012 | 08:44 AM
Look at it from outside through the windshield. There are two plastic covers that pry out. Underneath those are two screws.
Old Oct 10, 2012 | 07:34 AM
91DxRob's Avatar
oh ok cool thanks..
Now I have to figure out what's going on with my power steering at slow speeds... it doesn't seem to be working very well... normallly easy to make sharp turns(like into a parking space..) are not so easy all of the sudden.. Unless its just a cold hearted pain in the **** car thing...
mudhenFUF
Jan 16, 2023 08:43 PM
jberenyi
Mar 15, 2012 10:54 AM
RhysCivic
Jun 5, 2008 03:26 PM
MAKIN_A_KILLA_HATCH
Apr 22, 2008 08:12 PM
nigel_miguel
Mar 18, 2006 01:33 AM
