Speedo Not Workin??
Old Dec 16, 2010 | 05:51 PM
1.6LNVTEC's Avatar
Default Speedo Not Workin??
I am getting this 96 civic dx and the speedo does not work but everything else works like rpm and ****. Is this a bad fix or something not hard???
Old Dec 17, 2010 | 05:23 AM
Could be a number of things. Could be the speedo itself (and you would grab a junkyard cluster to swap out to fix this). Could be the wiring harness (just trace wires and look for a problem.) Could be the Vehicle Speed Sensor (VSS).
Old Dec 17, 2010 | 06:00 AM
1.6LNVTEC's Avatar
Alot of ppl said it was the VSS I was gonna try that first
Old Dec 17, 2010 | 07:18 AM
DaOne's Avatar
does the tripmeter and odometer work? If they work then its probably not the VSS.
Old Dec 17, 2010 | 08:22 AM
1.6LNVTEC's Avatar
Ok so if they do work then what would it be???
Old Dec 17, 2010 | 12:39 PM
DaOne's Avatar
When that happened to me it was the cluster itself.
sometimes it would work (for like 2 min), and most of the time it wouldnt(like 99% of the time).
i swapped the speedometer and it fixed it.
I went to the junkyard and got the speedometer for 14 bucks.
Old Dec 17, 2010 | 08:56 PM
1.6LNVTEC's Avatar
do you have to get the whole dash cuz it was out of a auto 96 cuz the coupe 5 speed didnt have a tach
Old Dec 17, 2010 | 09:04 PM
DaOne's Avatar
nah man just take the speedometer part
its only a few screws u take off from the back of the cluster if i remember correctly.
If the odometer and tripmeter work, then that means your VSS is working, because they get the signal from the vss as well.
Old Dec 17, 2010 | 09:08 PM
1.6LNVTEC's Avatar
ok is there anything else that would screw it up ?
Old Dec 17, 2010 | 09:26 PM
DaOne's Avatar
That should do it...
If not you can just return the speedometer to the junkyard, or at least we get 30 days over here...
