Speedo Still not working???
Old Jan 13, 2011 | 07:26 AM
1.6LNVTEC's Avatar
Idk I bought the car like it and yea CEL is on
Old Jan 16, 2011 | 07:48 PM
1.6LNVTEC's Avatar
What is Fuse 15 problem????
Old Jan 16, 2011 | 09:04 PM
If the CEL is on, then pull the codes and post them. If you have code 17, a common problem is the VSS connector. Check that first.
Also click the Fuse 15 link in my signature.
Old Jan 22, 2011 | 08:42 PM
1.6LNVTEC's Avatar
So I got a speedo from the junk yard and speedo still not working what else can it be now??
Old Jan 22, 2011 | 09:33 PM
DaOne's Avatar
Whats the check engine light on for?
have you checked what codes its throwing?
Old Jan 23, 2011 | 06:20 PM
1.6LNVTEC's Avatar
a P1337 undifined code
Old Jan 23, 2011 | 08:58 PM
DaOne's Avatar
Originally Posted by lsvtecEK4
engine speed fluctuation sensor is driven off the crank, a seperate exciter ring with a magnetic sensor that recieves a signal when each tool passes. your ECU is no longer seeing this signal. most likely bad wiring or a bad sensor. you do have to remove the crank pulley and atleast lower timing belt cover. if you have no experience working cars... then here...
The scan tool indicates Diagnostic Trouble Code (DTC) P1337: No signal in the Crankshaft Speed Fluctuation (CKF) sensor circuit.
Description
The diagnostic system has a pulser rotor on the crankshaft and a pulse pick-up sensor on the engine block. The ECM/PCM monitors the crankshaft speed fluctuation based on the CKF sensor signal, and judges that an engine misfire occurred if the fluctuation goes beyond a predetermined limit.
Got that off another forum.
Honestly did you even try googleing the code... google is your friend took me about 10 seconds to come up with 1.5 thousand results about "code P1337 honda".
Old Jan 24, 2011 | 10:27 AM
1.6LNVTEC's Avatar
yeah ik i read that its either the sensor or one of the wires is bad and what else can i do bout my speedo
Old Jan 24, 2011 | 02:12 PM
DaOne's Avatar
Well the code seems to be related to your problem with your speedo (just by looking at 1 thread i searched)......
chrisroug
Oct 2, 2006 11:36 AM
derekdunham
Nov 20, 2005 10:30 AM
nesh_uk
Oct 30, 2005 12:14 PM
cfauvel
Sep 22, 2005 01:23 PM
derekdunham
Jul 25, 2005 10:39 AM
