SPEEDOMETER not workin?
Old May 19, 2010 | 05:47 PM
c4rtm4n's Avatar
Post SPEEDOMETER not workin?
my speedometer is not working , i bought a brand new speed senso & used panel n still not working... wat else can i do to fix thiz problem.......
Old May 19, 2010 | 06:58 PM
DaOne's Avatar
are either of your miles movig? the trip meter and the other one...(forgot what its called lol)
Old May 20, 2010 | 12:28 PM
c4rtm4n's Avatar
Nooo .... PANEL Has 3 Circles well the one on the middle with the miles n speed is not working other two yes. on the left ram i think on the right gas level n Temp working .........
Old May 20, 2010 | 01:04 PM
Check if sensor plug is corroded also be sure power and ground are reaching the sensor. You can check the operation of the sensor by probing the output wire with everything plugged in and the key on (engine not running). Put the transmission neutral, lift one wheel of the ground and turn it slowly by hand. The output voltage should turn on and off.
If the sensor is not working, the CEL should come on with a speed sensor code after driving. I think it is triggered by going downhill or coasting in gear.
It's possible for the speedo head to be dead in a way that neither speed or odometer works. If you don't get a CEL and the cruise control (if equipped) works, it's probably the head itself. Pull the cluster and check that the screws in the back are tight, they make electrical contact.
Old May 20, 2010 | 09:14 PM
c4rtm4n's Avatar
thanks i will try this steps on the weekend i let you know if everything works thanks for your info ....
Old May 21, 2010 | 04:25 AM
Correction: in order to do the sensor test, transmission must be in neutral.
1.6LNVTEC
Dec 18, 2010 09:20 PM
civicvtec95
17
Jul 10, 2010 03:50 PM
zilliboy
Nov 28, 2008 05:40 PM
POLYTHING
Mar 23, 2007 11:16 PM
01CivicEX
Nov 28, 2005 06:16 PM
