speedometer still doesnt work
Old Feb 1, 2010 | 04:28 PM
churritos567's Avatar
Default speedometer still doesnt work
i got a new vss for my 1993 honda civic dx and my speedometer nor odometer doesnt work and i checked the wiring and the harness isnt opened or damaged at all? coould it be a fuze?
Old Feb 1, 2010 | 04:34 PM
black95coupe's Avatar
i fixed mine by changing the actual speedo but now my dash lights don't work???
Old Feb 1, 2010 | 04:37 PM
Do you have code 17 for the VSS circuit?
Old Feb 1, 2010 | 05:52 PM
everyother day it comes on but when i try to pull the CODE with the key on it doesnt say anything. i also a couple weeks ago tested the wiring on it and found 11.49v on one of the wires on the plug is that normal?
Old Feb 2, 2010 | 09:00 PM
the code does not come one anymore so it isnt the circuit i got a brand new vss and i did tthe diagnostic test on the vss plug and its at the spec. could it be the gauge cluster?
Old Feb 3, 2010 | 10:36 AM
DaOne's Avatar
yes it could be the gage cluster,
for me it was.
Old Feb 3, 2010 | 01:21 PM
The 3 wires on the VSS are ignition power (battery voltage), ground, and output. If you don't get a CEL though you were driving half an hour with no speed indicated, the VSS is probably OK and the problem is the cluster.
Jonathan_89_DX
Apr 27, 2011 03:22 PM
03civex
15
Oct 28, 2008 08:20 PM
kyleag89
Jun 8, 2007 06:23 AM
sohc_vtec
Apr 21, 2007 11:09 AM
lzyga05
May 29, 2006 09:55 AM
