squeek/squeal while accelerating at a low rpm
Old May 10, 2009 | 09:51 PM
megafandrew's Avatar
Default squeek/squeal while accelerating at a low rpm
Hey guys I have a proble I will post here as Im not sure specifically what it is. Basically this is what happens, Im going to drive the car or driving downtown,highway, anywhere and heres what happens. I accelerate in 1st, no problem, shift at about 3k and the needle drops down to 1.8 or so? as I push the gas pedal I here a squeal/squeek noise for the briefest moment until the needle goes past mabey 2.3/4 k and then its gone. Is this my timing belt or alternator or something or am I just shifting too low and straining something in the motor/drivetrain. Its not a really loud noise or nothing but I notice it, has been happening for a while now, what does it sound like to you guy's? (sorry Im clueless on this one and dont want to just start replacing things that don't need to be)
Old May 11, 2009 | 05:24 AM
You may have a loose or cracked exhaust heat shield.
Old May 11, 2009 | 08:03 PM
Ron is this the shield by the manifold? or under the car somewhere? I am thinking it could be my timing belt as well as its probally do for a change. How hard exactly is it to change a timing belt on a 94 civic with no options? Im want to sell the car but Ive got to fix the issue first I would think ;S
Old May 11, 2009 | 08:08 PM
Sounds like a bearing in an accessory's pulley, one of the drive belts slipping, or the bearing in the idler pulley.
Old May 11, 2009 | 08:12 PM
Aluminum heat shields are located from exhaust pipe A to past the cat.
What makes you believe the noise is coming from the timing belt area?
Old May 12, 2009 | 02:01 PM
Im not sure someone mentioned to me that it could be the timing belt about to break loose or its slipping?. I suppose I may have to take it in somewhere and let a technician check it out just so I dont spend a bunch on parts I dont need although I hate getting other people to fix/work on my car
Old May 12, 2009 | 02:40 PM
If you can reproduce the noise by revving the engine in neutral, try to pinpoint the source of the sound.
Old May 12, 2009 | 03:14 PM
The timing belt wouldn't make a squeak/squeal noise.
Another possibility is the water pump or the timing belt tensioner.
Old May 12, 2009 | 08:05 PM
thanks for the suggestions trust, now is it possible for me to check these for the issue myself?
Old May 12, 2009 | 08:11 PM
Yea, but it's better to check the accessories first.
Remove the power steering drive belt (if you have it). Start engine. Check for noise. If the noise is gone, it's your power steering pump bearing or the belt is slipping.
If the noise doesn't go away, remove the A/C belt (if you have one). Start the engine. Check for noise. If the noise is gone, it's either a slipping A/C belt, the compressor, or more likely the idler pulley bearing.
If the noise still doesn't go away, remove the alternator belt. Start the engine, check for noise. If the noise is gone, it's the alternator bearing or the belt is slipping.
If the noise is still there after removing all of those belts, then you have just ruled out all the accessories.
MrGonzo123
Sep 15, 2012 10:12 PM
hatchback virgin
Jan 4, 2009 04:00 PM
yalmissari
May 27, 2007 03:12 PM
elysian
Feb 15, 2006 08:09 PM
Falhawk
Jul 14, 2005 03:12 PM
