Squeeking sound when I rev engine
Old Mar 31, 2008 | 08:26 AM
SCUBAman's Avatar
Default Squeeking sound when I rev engine
I just bought a 01 civic 2dr lx and I noticed that when I rev theengine up even just in normal driving I can hear a squeeking sound in the engine that sounds to me like an belt maby the fan belt? Im not sure what to look for any help would be great.
Old Mar 31, 2008 | 08:38 AM
Default RE: Squeeking sound when I rev engine
Yeah, I would start be checking whether any of the three drive belts (PS/AC/Alt) are loose or glazed.
Old Apr 9, 2008 | 01:14 PM
SCUBAman's Avatar
none of them seem to be loose. anything else i can check?
Old Apr 9, 2008 | 01:21 PM
GOTeg?'s Avatar
check ur pulleys...
Old Apr 9, 2008 | 03:23 PM
gin0o0o's Avatar
check heatshields?
Old Apr 9, 2008 | 03:32 PM
gwl's Avatar
gwl
I had a very slight squeak when I used to rev my motor, it didn't happen all the time. I couldn't figured it out. It went away when the timing belt and the assoiciated accessories were replaced.
Old Apr 9, 2008 | 03:36 PM
Mr Mobsta Man's Avatar
Civics do not have fan belts... I still say it is a belt even if it doesn't seem loose.
Old Apr 9, 2008 | 03:56 PM
sto73's Avatar
try some belt dressing. if that makes it temporaroly go away then its the belts.replace them this is not a permenent solution. if its just a squeak could also be a slightly loose motor mount.
Old Apr 9, 2008 | 07:43 PM
i know that when i had a squeak on my belts, when i turned the A/C on it got a lot worse, and using that info i found out that it was in fact the a/c belt. maybe this will help you narrow it down
Capnx
Nov 26, 2011 01:35 PM
civic96man
Nov 6, 2010 04:18 AM
burgernuds
Aug 22, 2007 07:20 AM
alwaysneednewrubber
Apr 24, 2007 05:09 PM
01blackcivic
Nov 8, 2005 03:33 PM
