srs light
Old Jul 28, 2006 | 01:27 PM
pappabear's Avatar
Default srs light
I have a 2003 civic ex. The srs light stays on all the time. Disconnected the battery- to re set, didn't help. Is there a problem with the light or airbags? Maybe a recall I didn't know about? Thanks for your help.
Old Jul 28, 2006 | 02:45 PM
Type R's Avatar
Default RE: srs light
Did you have the batterie disconnectet or recharged before the srs light came on?
ORIGINAL: pappabear
Old Jul 30, 2006 | 09:54 PM
pappabear's Avatar
No, the battery wasn't disconnected prior to the srs light coming on. It just came on out of the blue.
Old Jul 30, 2006 | 10:16 PM
fglaustin's Avatar
srs (?) - is that the one telling you it is time for maintenance.
there is such on a old audi i have.
comes on every (so many thousand) miles - time to replace oxygen sensor (i think).
there is a trip switch to reset it.
Old Jul 30, 2006 | 10:45 PM
Fiirkan's Avatar
srs is for the airbags. not the check engine light.
Old Jul 31, 2006 | 01:21 PM
VTECivic95's Avatar
did you pull the srs fuse out? on my friends '94 civic his srs light is on all the time and i asked him why that is and he said its been like that ever since he pulled the fuse for it out on accident and put it back in. he said he disconnected the battery and everything and it still comes on all the time regardless. hope that helps!
Old Aug 1, 2006 | 08:40 AM
pappabear's Avatar
I did pull the srs fuse out. But only afterwards to try to reset the srs light. No luck though!
Old Sep 6, 2006 | 09:09 PM
coronakid's Avatar
I talked to a guy that worked for a Honda dealer, he says you have to have it reset by someone with the ECU or whatever they call the computer that resets the lights. MY SRS lights on also, if you take your seats out and re-install them make sure you plug your harnesses back in before you start your car, or your srs light stays on.
It's $60 at the dealer, maybe less at a shop that works on imports.
Old Sep 6, 2006 | 09:30 PM
slovic94's Avatar
ill vouch for that with the seats. who would have thought a seat belt contact would make that big of a deal??
Old Sep 6, 2006 | 10:36 PM
fglaustin's Avatar
thanxs for the reply.
remind me to never sell my 1988.
fivebells
Aug 9, 2014 06:10 PM
houstonwide
Nov 17, 2005 09:57 PM
vmf
Aug 1, 2005 11:43 AM
Josh1122
May 4, 2005 05:50 PM
ettrump
Feb 23, 2005 05:28 PM
