starting (fuel?) issues
so when i start my hatch it will start after 3 or 4 cranks if i keep my foot to the floor
then itll idle for about 10-15 seconds then stutter and die
i replaced my fuel filter and it started a lil bit faster but still stuttered and died
if i keep my rpms up the engine will stay running
opinions?
opinions?
HAVE YOU TRIED TURNING THE KEY?
As I said earlier on AIM , check spark plugs and wires. Check for possible shorted out wires. < my buddies 240 had exact same issues. Ended up being a amp wire that grounded out somewhere on the body. Thing did not have a fuse. > Check the injectors, all two of them. lol. If all that fails, try your rex's fuel pump. =)
SHE RUNS!
cleaned the dizzy and ran seafoam through the tank now she purrs like a kitten
but the dizzy still feels and sounds like somethings clunking around in it
how bad is that to drive with? im not keeping the engine very long but will have to drive it for like a month
also it sounds like i have a high idle but i have no tach
could that be caused by the dizzy or should i clean the iacv and fitv?
wait does dpfi even have those? lol
totenkopf
May 31, 2007 03:36 PM
shawnpdx
May 23, 2006 07:20 PM
