starting problems
So yesterday morning I went out to start my car, I go to turn the key and nothing happened all of the lights were lit up but it didn’t start. So I turn the key three more times and it started. And it did it all day today when I tried to start it. So tonight I pulled my car into my garage to take a look at it. I cleaned my battery terminals, checked the ground wires, and the connections to the starter and it all look good. So what do you guys think it might be? o ya i drive a 94 civic ex with the d16z6 5-speed
could be a coroded terminal on the starer or the wire corroded... most likely the small starter activation wire.... pull the wire and put a test light on it and make sure its actualy geting power everytime ya hit the key..... you could also hardwire that starter wire... run a wire into the car thru the firewall and simply wire a momentary switch to it and wire it to a power source in the fuse box.....
cause it might also be the ignition contacts..... several things it could be...... preaty easy to bypass it also....
don't hardwire anything..
mickey mouse way of doing things
pull the black/white wire off at starter solenoid , use a test lite , have someone try to start the car ( it won't start with the wire unplugged) ,, if you get power at the black/white wire ,,most likely you got a bad starter
if no power could be a bad starter realy or a bad clutch switch
let us know
let us know
totenkopf
May 31, 2007 03:36 PM
